Registrato Mon, 31 Jan 2022 12:52:29 GMT di Mayra Rossi
We have 2 string fields in same cabinet:
first contain string corrisponding to document ID
second contain multiple strings corrisponding to documents ID
Example:
TXT_ID_DOC --> 8929
RELATED_DOC --> 10202, 10747
If I create relation with condition : RELATED_DOC contain TXT_ID_DOC doesn't work.
How can we solve that?
Registrato Tue, 08 Feb 2022 00:00:14 GMT di Matthias Wieland Senior Director Support EMEA
Dear Mayra Rossi! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-170111-F2Z7Y for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Registrato Tue, 08 Feb 2022 13:04:31 GMT di Morten Ravn
have just testet on my Cloud system.. and there the related document works..&nbsp;<br> <br> it justet with these fields..<br> <br> First record:<br> Firstname : 2233<br> <br> Second record<br> Last Name : 2211, 2233 and also 2233, 2211<br> <br> If i am on the document with the first name filled out then the relation works.. because my relation is with Last Name contains Firstname<br> <br> <br> &nbsp;
