Registrato Thu, 04 Jun 2020 13:27:34 GMT di Tony Whitten System Administrator
Is DocuWare 7.0 compatible with SQL Server 2019?
Registrato Thu, 04 Jun 2020 13:48:09 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Tony,
That combination is officially not supported (see https://dw-help.azurefd.net/version/7-0/#/home/55049/2/2 ), but it could probably work anyway.
The first DocuWare Version which officially supports MSSQL 2019 is 7.3 (see https://dw-help.azurefd.net/#/home/55049/2/2 )
DocuWare System Configuration
