Registrato Tue, 10 Mar 2020 07:31:36 GMT di Mayra Rossi
There's the possibility to include table field in CSV Export?
Registrato Tue, 10 Mar 2020 12:40:50 GMT di Christopher Nicoli Project Manager-Sr Systems Engineer
No, you have to copy table field to a keywoard field then you can export
Registrato Tue, 10 Mar 2020 12:58:51 GMT di Mayra Rossi
To export a keyword field is mandatory to copy content to a text field, right?
Registrato Tue, 10 Mar 2020 16:07:42 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Mayra,
yes, if you do not wish to use the Platform .NET/REST API, then you need to convert the table field to a keyword field to a text field.
When Programming with the REST API, you can also export the data without needing to convert it.
