Registrato Tue, 17 Jun 2025 07:25:59 GMT di Mohammad Mizanur Rahman Orogenic Resources BD Limited Mr.
Error: 500 Internal Server Error (ORA-01013: user requested cancel of current operation)
Issue Analysis
  • Error: ORA-01013 typically occurs when a client or middle-tier component (like the web server or app server) cancels a long-running operation.
  • HTTP 500: Indicates a server-side issue, not a client/browser issue.
  • Context: The error occurs during a form submission on your DocuWare system running on UCB's production environment.
If any one can resolve this please let us know
Registrato Wed, 18 Jun 2025 04:40:57 GMT di Mohammad Mizanur Rahman Orogenic Resources BD Limited Mr.
The TNS.ORA responding from the old name and IP, how to resolve this issue?
Registrato Wed, 18 Jun 2025 09:14:46 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Mohammad Mizanur Rahman,
This is obviously a problem from the Oracle Database connection.
I am not an Oracle expert and can't help with this specific issue.
However, please keep in mind, that DocuWare version 7.9 is the most recent version which still supports Oracle databases.
DocuWare 7.10 and newer do not support Oracle Databases anymore, so you have to move away from the Oracle database anyway.
Which Version of DocuWare are you currently using?
Registrato Thu, 19 Jun 2025 04:30:26 GMT di Mohammad Mizanur Rahman Orogenic Resources BD Limited Mr.
We are currently using version 7.8. Yesterday, we increased the session timeout in the DocuWare server under the bin folder dll.config file. The issue appears to be resolved for now, but we will continue to monitor the system closely over the next 2–3 days.
