Registrato Wed, 03 Jun 2020 19:03:48 GMT di Farzali Babekhan Solution Integrator
Hi
I am setting up Docuware cloud SMTP server.    I have used multiple SMTP severs namely:   hmailserver (on local machine), Yahoo account, and gmail.    I know the my infomartion is correct, I need some help here, Thank you .
Following error sample is from google. When I use STARTTLS
If I use TSL or SSL specifically it give me the following error:
Registrato Thu, 04 Jun 2020 07:39:13 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Farzali,
the error screenshots do not show up for me. Please reupload them - pasting inline images is not possible in this forum. You need to either attach them or upload to some image hosting platform and embed the image in your post.
Registrato Thu, 04 Jun 2020 07:48:46 GMT di Farzali Babekhan Solution Integrator
When I test either with  TLS or SSL
when I test with
StartTLS:
Registrato Thu, 04 Jun 2020 07:52:37 GMT di Farzali Babekhan Solution Integrator
Hello Simon
I pasted the images but I don't see them here....??  I will also attach an screen shot.
