Registrato Wed, 05 Jun 2019 12:46:30 GMT di Kim Sims Technical Solution Architect
Situation is this:
New Installation
2 Import Configurations {1 direct import for manual indexing, 1 using metadata}
Manual indexing import job functions flawlessly
Import job using dwcontrol file stops almost as soon as it starts
Both network shares have same permissions and are on the same server
I've tried:
Creating new share on DW server for monitoring
Changed Doc Tray within the Import Config
Modified the Import Config for direct import into the file cabinet
Created new Import Job
Created new Import Config
Not sure what else to try here. I have run the DTA log collector and have included the resulting zip file along with a copy of the dwcontrol file for review / help.
Any ideas would be greatly appreciated.
Registrato Wed, 05 Jun 2019 18:27:23 GMT di Kim Sims Technical Solution Architect
Just to follow up on this matter. We finally determined where the import was failing.
We found that the .dwcontrol file, that was being generated by AutoStore, was missing a double quote (") in the value for the index field.
Once it was added, it imported successfully.
Not sure why it would actually stop the import process, but, nevertheless, it is resolved now.
