Registrato Tue, 09 Mar 2021 14:48:02 GMT di Steve Shriver Application Specialist
An end user of a cloud system reports that stamps are using UTC instead of the local time when applied to a document. Also, email notifications seem to be running late and based on UTC instead of local time.
Is there a setting that needs adjusted?
Registrato Tue, 09 Mar 2021 16:30:02 GMT di Steve Shriver Application Specialist
Upon further investigation it appears that the correct local time is used when the stamp is first applied. However when the document is reviewed later, 5 hours has been added to the previously stamped time. As the user is in EST that makes the new time UTC.
