Registrato Thu, 19 Jun 2025 12:50:24 GMT di Devlin Boby Software Engineer
Is there a way to check which users are actively using the system, or their last login?
Registrato Mon, 23 Jun 2025 09:18:17 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Devlin,
Login time is only saved in the audit logs, if you enabled it.
You can look at active sessions in the Administration under "Tools" -> "Connections Overview".
Screenshot for the above.
