Registrato Wed, 31 Oct 2018 18:28:26 GMT di Joe Heaton VP
I have users indexing data from a list.  using edit index data.  Once they edit the data I would like a stamp that first saves what they did (in case they did not hit save) and then stamp the document which changes an unseen index entry.
Is this possible?
Registrato Wed, 31 Oct 2018 18:36:31 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Joe,
Let me test that for you. I have an idea.
Registrato Wed, 31 Oct 2018 18:49:03 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Sorry Joe. It is not possible. The edit index entries and applying the stamp are 2 different threads and are not dependant on each other. Basically, they do not "read" each others thread data. So the user needs to save in index data entry.
