Registrato Tue, 14 Dec 2021 16:51:06 GMT di Daryl Foxhoven
Does anyone know how of if it's possible (and if not, will it be) how to use a Multi-Column select list with Forms.  We have a Form that is being filled out, and once the user fills out the Room #, we want the Resident Name to be filtered so that not all resident names show up but ONLY the resident Name for that Room #.  I know this can be done in DocuWare, but when I try to use it in Forms, it ONLY ever pulls the one column, so the Room # is the ONLY thing that shows up for Resident Name....it's almost like it doesn't support Multi-Column?
Registrato Tue, 14 Dec 2021 17:00:09 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Daryl,
multi-column select lists are coming to Forms in Version 7.6, release date will most likely be in Q1 or Q2 of 2022.
