Registrato Fri, 18 Oct 2019 13:57:44 GMT di Steve Shriver Application Specialist
Does anyone know where I can find more specific documentation on using the List type variable for the above named? (V7.1)
If I create a Role type variable named "Supervisors" and check the List option, what entry type can I use to load that variable? (I'm assuming an Arithmetic Expression like "Supervisor One" AND "Supervisor Two" AND "Supervisor Three").
And if I use it in a condition what will that variable contain? For example in a Validation, WF_ASSIGNED_TO = GV_SUPERVISORS, does it check each and compare for each element?
Registrato Fri, 18 Oct 2019 13:58:44 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Steve Shriver! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-112598-K0J1F for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
Registrato Thu, 06 Mar 2025 06:23:59 GMT di Paolina Lee Document Control Manager
Hi @Matthias,
Can I please know where I can find the SR-112598-K0J1F and how it was resolved?
Thank you!
