Registrato Tue, 16 Oct 2018 08:26:08 GMT di Hameed Ogbara - left 05.2022 Technical Support
Good Morning,
How do i get the list of all indexed entries in an index field? For example, I have an index field called "Document Type". I want to have all the list of the index entries on the Document Type Field in an Excel format.
Regards.
Registrato Fri, 19 Oct 2018 09:42:55 GMT di Simon H. Hellmann Wedderhoff IT GmbH Systemadministrator
Hello Hameed,
the easiest way is probably a simple SQL Statement to get the info from your dwdata.
SELECT DOCTYPE FROM archive GROUP BY DOCTYPE
This should give back a list of all the values stored in the index field "DOCTYPE" from your archive. You can then export that list to excel, depending on what Software you use to access the database.
