Registrato Fri, 08 Feb 2019 15:04:04 GMT di Jason Wilson Solutions Sales Specialist
Is tehre documentation that explains setup of DW Desktop Apps in a terminal server environment for DW 7, primarily Cloud? I saw a document in FAQ for 6.9 but didnt know if it was still accurate for 7.0 Cloud.
Registrato Fri, 08 Feb 2019 15:11:12 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Jason,
The principal for 7 is the same as with 6.9. Install the apps on the terminal server, publish them and you should be good to go.
Registrato Fri, 08 Feb 2019 15:14:25 GMT di Jason Wilson Solutions Sales Specialist
Thanks Phil. Just wanted to make sure.
