Registrato Tue, 05 Feb 2019 21:27:38 GMT di Steve Shriver Application Specialist
In a previous version(s) of DocuWare, we could configure a Windows Explorer Client dialog that would pre-create a folder for every value in a select list associated with an index field in the dialog if that field was chosen as a level for the WEC, before any documents were added to the file cabinet.
I am unable to find that option on the configuration page in the dialogs/folders section of a file cabinet in version 7. Can anyone say if that feature is still available and where or how to configure it?
Registrato Thu, 07 Feb 2019 18:33:11 GMT di Steve Shriver Application Specialist
Just in case anyone wanted the answer to this question; Yes, the feature is still available. When creating or editing a folder structure, hold your cursor on a folder level to highlight it in blue and slide over to the far right and click on the 'advanced' link. This will allow you to choose the select list to show as empty folders.
