Registrato Mon, 19 Feb 2018 08:43:13 GMT di David Miguel Trujillo
Hello everyone,
I have to make an update from DW 5.1c to the last DW Version,
I would like to know if it is possible to make a DW request from the actual version and then install from zero the new DW version configure it as it is right now (users, index, and cabinets) and import the DW Request, do you think it is a good option? (the company as very few users and file cabinets),
Thanks in advance, David
Registrato Tue, 20 Feb 2018 11:27:19 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
David,
No. That is not possible. You must upgrade your system as per the Upgrade paths.
https://www.docuware.com/support_faq/index.php?action=artikel&cat=191&id...
