Registrato Tue, 28 Jul 2020 15:09:14 GMT di Josef Zayats
I've been trying to get the Duplicate Invoices check Store Validation JS Node webservice to work. I thought it would be pretty simple to adapt the sample for such a service Docuware has available on its Developers website.
So, after spending a lot of effort on this, the service that is accessing my Docuware Cloud system (7.2)  runs correctly only once or twice before giving me 401 error, and then I have to wait awhile before I can use the service again.
401 error means Authentication problem, and most likely the license I use to access Docuware system is not being released from previous access. I've been told that I need to use Token instead of username/password login for attempts after the 1st one. Unfortunately I have no idea how to that in the JS program. Can anyone assist? I have the following code - this is exactly how it came from the downloaded sample.
exports.isDuplicateInvoice = function (fileCabinetGUID, invoiceNo) {
    return new Promise((resolve, reject) => {
        var CookieJar = unirest.jar(true);
        //logon to DW PLATFORM and retrieve cookie;
        unirest.post(DWparameters.DWPlatformUrl + '/Account/Logon')
        .headers({'Accept': 'application/json', 'Content-Type': 'application/x-www-form-urlencoded'})
        .jar(CookieJar)
        .send({ 'UserName': DWparameters.DWPlatformUser, 'Password': DWparameters.DWPlatfromPassword, 'Organization': DWparameters.DWPlatformOrganization, 'RememberMe': false, 'RedirectToMyselfInCaseOfError': true })
        .end(function (response) {
            unirest.post(DWparameters.DWPlatformUrl + '/FileCabinets/'+ fileCabinetGUID +'/Query/DialogExpression?dialogId='+ DWparameters.DWSearchDialogGUIDForInvoiceSearch +'&format=table')
            .headers({'Accept': 'application/json', 'Content-Type': 'application/json'})
            .jar(CookieJar)
            .send({ 'Condition':[
                { 'DBName':DWparameters.fieldNameDOCNUMBER, 'Value': [invoiceNo] },
            'SortOrder':[],'ForceRefresh':true,'FlagConditions':{'IncludeCheckedOut':false},'Operation':'And','AdditionalResultFields':[],'Start':0,'Count':1})
                if (response.error) {
                    return reject(new Error(response.error.message));
                try {
                    var resultCount = response.body.Count.Value;
                    return resolve(resultCount == 0);
                } catch (error) {
                    return reject(new Error("Unable to retrieve similar invoices. Error:" + error));
Registrato Tue, 28 Jul 2020 15:10:14 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Josef Zayats! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-131523-Y5M9Y for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
