Registrato Fri, 07 Jun 2019 12:23:32 GMT di Christophe Mathieu Ricoh Luxembourg PSF sàrl Document Solutions Specialist
Does someone have any experience installing Intelligent Indexing on premise on Windows Server 2016 or Windows Server 2019 ? Because it is specified in documentation that Windows Server 2012 R2 is recommended.
Is there any tips&tricks for installing on 2016 or 2019 ?
Is it fully supported by Docuware if we install on 2016 & 2019 ?
Regards,
Christophe.
Registrato Mon, 10 Jun 2019 16:26:28 GMT di Gilles Sauvagnat Altexence
I did that on a Windows Server 2016
As usual,  not an easy task, Intellix is not "plug and play" module.
I do not know about the support. The Intelliw current version is around 4 years old
Should be a new one someday, hopefully in 2019.
Gilles
Registrato Wed, 12 Jun 2019 12:44:09 GMT di Christopher Nicoli Project Manager-Sr Systems Engineer
i've set this up on a server 2012 r2 machine. there is a huge manual that docuware provides with step by step instructions that must be followed exact.  unfortunately i do not know if on premise intellix supports 2016 or 2019
Registrato Wed, 12 Jun 2019 12:47:43 GMT di Christopher Nicoli Project Manager-Sr Systems Engineer
here is the manual in case you cant find it
