Registrato Thu, 11 Nov 2021 21:11:08 GMT di David Moore Co-Contract Administrator
we are indexing incoming invoices with Intelligent Indexing Service. I'm aware you can use a flat file to filter the content to ensure your vendor names are consistent with the data in their ERP.
I would like to come up with a solution to automatically keep the filtering flat file synced with the ERP database. I have established connections to the database for select list data. I know that there is a write-back option in AUTOINDEX to update the file used for indexing.
It seems all the necessary components are available to make this happen but I need help figuring it out. Thanks.
Registrato Thu, 18 Nov 2021 21:11:08 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear David Moore! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-164745-P8Y7H for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
