Registrato Tue, 22 Jan 2019 13:05:58 GMT di Kjetil Kulterud Service Owner
Is it possible to change the system entries? More specific "stored on"
Registrato Tue, 22 Jan 2019 13:11:25 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Kjetil,
Absolutely not. No system entry can be changed. That includes Stored Date Time, Stored By, Modified Date Time and Modified By.
Why would you want to change these entries anyway?
Registrato Wed, 23 Jan 2019 06:14:00 GMT di Kjetil Kulterud Service Owner
Ok, thanks
We are about to import 10 million documents from an old archive system, to DocuWare, and the customer asked if the "stored on" could be changed to match the "store date" meta data from the old system.
Then I guess I just create a new metadata field called "StoreDate" or something, and use that field instead.
