Registrato Fri, 13 Oct 2023 17:26:47 GMT di Carlos Andres Garcia System Admin
hola a la caomunidad,
he estado buscando la manera de conectar quieckbooks desktop que es el se usa en la compañia y no he podido encontrar una forma de hacerlo, agradezco la ayuda que me puedan brindar al respecto.
Registrato Fri, 20 Oct 2023 09:08:01 GMT di Tobias Getz DocuWare GmbH Team Leader Product Management
Hola Carlos Andres Garcia,
there is currently no native/direct integration between DocuWare and Quickbooks.
If you can consider third party integration then you can think about using Make.com with the DocuWare and the Quickbooks connector.
DocuWare GmbH
Registrato Fri, 07 Feb 2025 09:11:42 GMT di Paolina Lee Document Control Manager
Hi Tobias,
I’m also struggling with how to send data to QuickBooks via API or Make.com, as suggested by the DW team.
Since this post was created more than a year ago, are there any successful client cases we could refer to for setup guidance?
Thanks in advance.
Registrato Wed, 12 Feb 2025 12:40:49 GMT di Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Paolina,
some of our customers have integrations to Quickbooks. I forwarded this request internally and you will get an update from there.
DocuWare GmbH
