Registrato Mon, 08 Jan 2024 12:55:45 GMT di Pedro Jimenez ECM Manager
I would like to know if via API or other programming means, it is possible to create index level profiles by code.
Best Regards
Registrato Mon, 08 Jan 2024 18:56:26 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Pedro Jimenez,
almost none of the administrative work can be done with API currently.
Have a look at the API documentation developer.docuware.com and also on your DocuWare Platform Description ( /DocuWare/Platform/Home/XSL).
As far as I know, index value profiles are currently not included. You might want to open a request over at Uservoice.
