Registrato Mon, 09 Jun 2025 12:45:48 GMT di Gintautas Rokas IT Engineer
Maybe someone can find a way to run DocuWare.Export in the background?
C:\Program Files (x86)\DocuWare\Export\DocuWare.Export.exe
the problem is that task scheduler run only app, but I need to press additionally "Perform Export Now" button.
Has DocuWare.export.exe CLI (command-line interface)?
command like
C:\Program Files (x86)\DocuWare\Export>DocuWare.export.exe /?
or
C:\Program Files (x86)\DocuWare\Export>DocuWare.export.exe --help
gives nothing
I need to run exe file with my configuration (attached) every hour in background
Registrato Tue, 17 Jun 2025 00:00:37 GMT di Matthias Wieland Senior Director Support EMEA
Dear Gintautas Rokas! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-264721-R2Z8G for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Registrato Wed, 18 Jun 2025 06:00:00 GMT di Manuel Brausch Technician Software Support
When the export is configured to run on a schedule, the process takes place automatically in the background without opening the application or the need for manual user interaction.
Further information can be found in this article: https://support.docuware.com/en-us/knowledgebase/article/KBA-36581
