Registrato Wed, 06 Aug 2025 18:10:16 GMT di Waylon Courvell Initium Softworks LLC Technical Support Engineer
I have a few questions for a customer of ours. They Use Microsoft Azure Information Protection and Purview. The have ingested Documents with Purview labels and they are unable to view the documents.<br><br> Does DocuWare have plans to integrate and support Microsoft Azure Information Protection?<br> Can you tell me more about DocuWare native encryption?<br> What type is it?<br> What is the encryption for Cloud?&#160;<br> Is On-Prem file cabinet encryption limited to enterprise systems only? If so, what is the upgrade cost from DocuWare PROFESSIONAL Server?<br> <br> Can you please tell me about DocuWare native Data loss prevention?<br> <br> Thanks,
Registrato Thu, 07 Aug 2025 12:36:16 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Waylon,
did you want to open a support ticket instead of posting to the Forum?
I do not know about the future plans of DocuWare integrations.
But all the info you could need about the security can be found in the WhitePaper Cloud and WhitePapers Document Security.
They can be found here: https://knowledgecenter.docuware.com/docs/en/white-paper
The file encryption is only available in Cloud (always enabled) or on Enterprise server (default disabled, can be enabled per file cabinet).
You can get information about the price from your DocuWare Partner contact.
