Registrato Thu, 26 Sep 2019 18:48:02 GMT di David Blake Ricoh USA Sr. Solution Integrator
The Audit Reports do not provide any detail.  Is this normal, or can it be enabled to provide details?  When changes are made, it is expected to report what was changed. This is especially important to keep track of index field changes.
I've attached an example image where the properties and value are not filled in, yet I did create a new External Select List with values included.
Registrato Thu, 26 Sep 2019 18:49:02 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear David Blake! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-93253-Y4Z6L for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
