Registrato Mon, 03 Oct 2022 11:44:56 GMT di Andreas Moroder Direktor des IT-Amts
we have Docuware 7.2 with sql server.**
Is it possible to migrate the docuware DB to Oracle?
Is Oracle 19c supported?
Is the diskspace necessary in oracle the same as with sql-server?
**We will upgrade to the last release in Q1 2023.
Greetings
Andreas
Registrato Tue, 04 Oct 2022 07:06:01 GMT di Marcin Kratiuk
Such a migration is possible with the PowerCopy tool, which allows you to move configurations and documents using only native DocuWare functions without referring directly to the database.
Kind Regards,
Marcin
