Toggle navigation
Forum
Knowledge Base
Stato
Download
Richieste di supporto
Tutto
Tutto
Pagine Web
Forum
Articoli della Knowledge Base
Filtro di Ricerca
Tutto
Pagine Web
Forum
Trova risposte
Italiano
Deutsch
Español
Français
English
日本語
Italiano
Accedi
Home
Forum della comunità
Questions about usage and configuration
SQL account change
SQL account change
Registrato
Tue, 12 Mar 2019 18:15:16 GMT
di
Kevin Fultz
Engineer Software Support
What all would be involved in changing the SQL account from a local account with admin privileges to a domain account and what would be the potential issues?
Registrato
Tue, 12 Mar 2019 18:20:18 GMT
di
Casey Miller
Director of Technical Services
I think this would be different depending on what version of DocuWare you are on.
Registrato
Tue, 12 Mar 2019 18:22:17 GMT
di
Kevin Fultz
This would be for Version 7
Registrato
Tue, 12 Mar 2019 18:32:44 GMT
di
Casey Miller
Pretty new to 7 and you will want to double check but you should just be able to create the domain user in MSSQL and make sure mixed Auth is turned on. The user will need the DB.creator role at least. Then sign into docuware admin tool and change the login to the new login for each database. I am not sure if there is still a settings file for each service like before that has this in it too..
Ottieni aiuto
Cerca nella Knowledge Base
Chiedi alla community
Nuova richiesta di assistenza
