Registrato Fri, 02 Feb 2024 11:54:41 GMT di George Charisis Presales Consultant
Hi everyone,
I'm working on a project and came across a situation where I need some guidance. In our system, we have various metadata properties associated with items, one of which is a "Supplier" property. This property can take values from a predefined list of suppliers we work with.
Here's my question: Is it possible to dynamically show or hide additional metadata properties based on the supplier selected? For instance, if Supplier A is selected, certain properties become visible for entry or display, whereas if Supplier B is chosen, a different set of properties becomes relevant and should be shown instead.
Has anyone implemented something similar in their projects? If so, could you share how you approached this requirement? Any insights or suggestions on how to achieve this would be greatly appreciated.
Thank you in advance for your help and advice!
Registrato Fri, 02 Feb 2024 13:08:14 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello George Charisis,
conditional field visibility is currently only available in DocuWare Forms.
Store Dialogs, C2O Configurations, Workflow decisions etc. all do not support conditional visibility at this point (DW Version 7.9).
