Registrato Thu, 30 Jan 2020 14:05:45 GMT di Steve Shriver Application Specialist
A validation in a workflow task is correct (the designer validates and does not prevent completion of configuration) but does not work in practice. The idea is to allow only a select list of users to execute the step.
The validation is:  WF_LOGGED_IN_USER = "user1" OR WF_LOGGED_IN_USER = "user2" OR WF_LOGGED_IN_USER = "user3" OR WF_LOGGED_IN_USER = "user4" OR... There are 11 users in this list.
The workflow designer does not complain about this, the OK button is enabled. But in practice these users are not able to execute the task and receive the 'condition not fulfilled' error message.
Is there a limit to the length of the condition, or some other syntax error visible here?
Registrato Thu, 30 Jan 2020 14:06:45 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Steve Shriver! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-119663-J3C7H for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
