Registrato Mon, 23 Dec 2019 09:17:59 GMT di David Miguel Trujillo Técnico
Hello everybody, good morning
I wanted to ask if it is possible to make a copy of a text type index to a number type index by mass casting, in a Docuware Cloud system,
Thank you very much for the help,
Best regards, David.
Registrato Tue, 24 Dec 2019 07:52:17 GMT di David Barlet Technical Manager
Hi David,
You can do that with arithmetics expression in a workflow (Index_Int = CInt(Index_Text). You can schedule this workflow to update your document.
Best regards,
David
