Registrato Thu, 13 Aug 2020 04:01:55 GMT di Fikri Mohd Asst. Manager, Solution Specialist
Im trying to develop Leave application process in Docuware. I have created external db that store number of available leave for employee. So the question are;
1. In Docuware Forms & Workflow, can I perform calculation in Forms for exp, by using 2 dates (Leave Start Date & End Date) will calculate number of days applied and populate into fields in Forms?
2. Possible to perform db lookups in forms designer?
3. How to update db after leave process completed? exp, total days remaining will be subtracted from the days applied.
Registrato Thu, 13 Aug 2020 04:02:55 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Fikri Mohd! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-132590-Q4J4N for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
