Registrato Fri, 11 Sep 2020 00:27:37 GMT di Stephen McBride Secondary Admin
I need to rename one of our file cabinets. It seems straightforward, and I renamed a test file cabinet without issue. I'm just wondering if anyone has any experience with doing that, and if there is anything I should be aware of? Any risk to workflows, lists, tasks, dialogs etc?
Thanks!
-Steve McBride
Registrato Thu, 17 Sep 2020 12:51:51 GMT di Craig Heintz SE
Depending on your version...My reference is v7+...renaming is not a problem.  Only the display name is changed.  All of the Database naming and storage location folder naming will stay the same so from a programatic stand point it will be fine.
