Registrato Mon, 15 Sep 2025 12:52:57 GMT di Gintautas Rokas IT Engineer
Is there a way to customize Tasks fields? One example is attached. For the customer needs to remove "Reminder date" and "Due date" and add one additional index field.
Registrato Mon, 15 Sep 2025 16:40:23 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Gintautas Rokas,
open the workflow you want to change the list view for in the workflow designer application.
There, you can use the "Task list" button to edit the columns, see screenshot.
Registrato Tue, 16 Sep 2025 06:01:01 GMT di Gintautas Rokas IT Engineer
thanks for the quick help, it helped
