Registrato Fri, 10 Jun 2022 11:57:02 GMT di Rhys Woolley Software Developer
I'm trying to create a Time Delay that hopefully waits until the current date is the same as the one in a Refresher Date Global Variable before continuing the workflow. Even though I have the Global Variable set up including an Assign Data step, I'm getting an error in the Time Delay that won't let me select any Global Variables
Registrato Fri, 10 Jun 2022 12:38:28 GMT di Fabian Kall
If I recall correctly, Your GV needs to be of type Date with Time.
