投稿済み Thu, 21 Nov 2019 09:05:55 GMT 、投稿者 Vincent Van Neer
Hi guys
Situation:
I have 1 invoice with multiple orders. Let's say Order12345, Order54321, Order98765.
All the orders are seperate documents that are stored in the archive "Finance".
When an invoice comes in, I have a "keyword-field" with all the orders that are related to the invoice.
A workflow starts and the first thing we want to do is to do a check if all the order documents are stored in DocuWare.
We already upgraded to DocuWare 7.2 to be able to search for documents in an archive.
Question:
Any idea how we can setup the workflow that it will check for each ordernumber in the keyword field if the document is present in DocuWare or not?
I could do it with a webservice but it won't be easy to get a web serivce up and running at the customers environment.
Is it possible within the Workflow designer without using a web service?
Kind regards
Vincent
投稿済み Thu, 21 Nov 2019 09:06:55 GMT 、投稿者 Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Vincent Van Neer! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-115330-D1S1C for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
