投稿済み Fri, 11 Oct 2019 16:09:02 GMT 、投稿者 Phillip Enns Systems Admin
Trying to use a form to populate multiple merge forms.  Most work as designed but a couple appear to be placing the data in random spots.  Tried recreating the failing merge forms but same issue occurs.  Attaching copies of screenshots as example.   Any ideas to correct appreciated.
投稿済み Fri, 11 Oct 2019 16:10:02 GMT 、投稿者 Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Phillip Enns! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-112028-K9N0P for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
投稿済み Fri, 18 Oct 2019 16:19:06 GMT 、投稿者 Phillip Enns Systems Admin
I have talked to support already regarding this issue and was informed issue due to fillable forms being used for merge forms.  Replaced forms with non fillable versions and problem resolved.
