投稿済み 約 6 年前 、投稿者 Nicolas Grondona Tecnico
Hi, i wanted to insert data in an external DB from docuware , is it that possible ?. If it is possible how will be the way to do it ?
投稿済み 約 6 年前 、投稿者 Andreas Ruttkamp
I think "Autoindex" is what you are searching for. You can read data from an external DB to fill index fields in docuware AND you can manipulate fields in external DB ...
