投稿済み Wed, 15 Aug 2018 17:33:45 GMT 、投稿者 Roy Slowiak
I have been working with select lists within forms and have noticed that some of the larger select lists get cut off for some unknown reason. Once I noticed this, I exported the CSV where the select list is pulling from and imported it into Excel. This CSV has about 1,300 entries. Once sorting the list from A-Z, I noticed there were only 1009 entries. For some reason, the select list is getting cut-off. This is an external select list.
Is there some type of limit on select lists within forms? If so, is there any way to change such limit?
投稿済み Thu, 13 Jun 2019 18:33:19 GMT 、投稿者 Nathan French ComDoc Systems Analyst
I have the same question.  The cutoff limit applies in this case to a file connection.
投稿済み Tue, 17 Nov 2020 12:44:12 GMT 、投稿者 César Javier Fois Acosta Consultant
I have the same problem, someone solved ?
投稿済み Tue, 19 Jan 2021 10:32:16 GMT 、投稿者 Jan Kanters Digital Transformation Enabler
If I remember well, the csv file size is limited to 4Mb.
So please check to remove whitespace while creating an export in Excel
Did you specify a filter on the external list ?
