投稿済み Fri, 10 Aug 2018 10:53:14 GMT 、投稿者 Callum McGlynn Technical Solutions Manager
The phased upgrade and inability for the desktop apps to be backwards compatible is causing a nightmare with the support/change side of things on the cloud.
Is there a way to run both 6.12 & 7 desktop apps at the same time to enable support of both systems?
We have the Admin tool running in both locally but really need to get the Workflow Designer working in both also.
投稿済み Fri, 10 Aug 2018 11:15:06 GMT 、投稿者 Maria Holden Sr. Director Software Support Americas & APAC
No, by product design it is not possible to run two different versions of desktops apps.
Regards,
Maria Holden
Manager Support –  Americas
投稿済み Fri, 10 Aug 2018 11:40:00 GMT 、投稿者 Callum McGlynn Technical Solutions Manager
Hi Maria,
There is no way to get around this even if just for the Workflow Designer? Will desktop apps be made backwards compatible at some point?
投稿済み Fri, 10 Aug 2018 11:45:39 GMT 、投稿者 Maria Holden Sr. Director Software Support Americas & APAC
It is not possible - nonethelss, the only work around will be to have separate workstation running desktop apps in a different version.
Regards,
Maria Holden
