投稿済み Thu, 20 Apr 2023 20:18:15 GMT 、投稿者 Edward Clarke Community Service Partners Director of Information Technology
I have a computer where the desktop client is installed but the install is messed up.&#160; I tried to uninstall it but it fails.&#160; I will not let you uninstall or install anything.&#160;<br> <br> Is there a way to force uninstall and cleanup of the desktop client without having to replace the computer? <div dir=ltr style=""> <div style="color:initial;font:initial;text-rendering:initial;writing-mode:initial;zoom:initial;alignment-baseline:initial;backface-visibility:initial;background:initial;baseline-shift:initial;border:initial;border-radius:initial;border-collapse:initial;box-shadow:initial;box-sizing:initial;caption-side:initial;clear:initial;clip:initial;clip-path:initial;clip-rule:initial;color-interpolation:initial;color-interpolation-filters:initial;color-rendering:initial;columns:initial;column-fill:initial;column-rule:initial;column-span:initial;counter-increment:initial;counter-reset:initial;cursor:initial;display:initial;dominant-baseline:initial;empty-cells:initial;fill:initial;fill-opacity:initial;fill-rule:initial;flex:initial;flex-flow:initial;float:initial;flood-color:initial;flood-opacity:initial;height:initial;image-rendering:initial;letter-spacing:initial;lighting-color:initial;line-break:initial;list-style:initial;margin:initial;mask:initial;max-height:initial;max-width:initial;min-height:initial;min-width:initial;opacity:initial;outline:initial;overflow:initial;padding:initial;perspective:initial;perspective-origin:initial;pointer-events:initial;position:absolute;ruby-position:initial;shape-rendering:initial;size:initial;speak:initial;stop-color:initial;stop-opacity:initial;stroke:initial;stroke-dasharray:initial;stroke-dashoffset:initial;stroke-linecap:initial;stroke-linejoin:initial;stroke-miterlimit:initial;stroke-opacity:initial;stroke-width:initial;table-layout:initial;text-align:initial;text-align-last:initial;text-anchor:initial;text-decoration:initial;text-emphasis-position:initial;text-indent:initial;text-overflow:initial;text-shadow:initial;text-transform:initial;text-underline-position:initial;transform-origin:initial;transform-style:initial;transition:initial;vertical-align:initial;visibility:initial;border-spacing:initial;white-space:initial;width:initial;word-break:initial;word-spacing:initial;z-index:2147483647;"></div> </div> <div style="color:initial;font:initial;text-rendering:initial;writing-mode:initial;zoom:initial;alignment-baseline:initial;backface-visibility:initial;background:initial;baseline-shift:initial;border:initial;border-radius:initial;border-collapse:initial;box-shadow:initial;box-sizing:initial;caption-side:initial;clear:initial;clip:initial;clip-path:initial;clip-rule:initial;color-interpolation:initial;color-interpolation-filters:initial;color-rendering:initial;columns:initial;column-fill:initial;column-rule:initial;column-span:initial;counter-increment:initial;counter-reset:initial;cursor:initial;display:initial;dominant-baseline:initial;empty-cells:initial;fill:initial;fill-opacity:initial;fill-rule:initial;flex:initial;flex-flow:initial;float:initial;flood-color:initial;flood-opacity:initial;height:initial;image-rendering:initial;letter-spacing:initial;lighting-color:initial;line-break:initial;list-style:initial;margin:initial;mask:initial;max-height:initial;max-width:initial;min-height:initial;min-width:initial;opacity:initial;outline:initial;overflow:initial;padding:initial;perspective:initial;perspective-origin:initial;pointer-events:initial;position:absolute;ruby-position:initial;shape-rendering:initial;size:initial;speak:initial;stop-color:initial;stop-opacity:initial;stroke:initial;stroke-dasharray:initial;stroke-dashoffset:initial;stroke-linecap:initial;stroke-linejoin:initial;stroke-miterlimit:initial;stroke-opacity:initial;stroke-width:initial;table-layout:initial;text-align:initial;text-align-last:initial;text-anchor:initial;text-decoration:initial;text-emphasis-position:initial;text-indent:initial;text-overflow:initial;text-shadow:initial;text-transform:initial;text-underline-position:initial;transform-origin:initial;transform-style:initial;transition:initial;vertical-align:initial;visibility:initial;border-spacing:initial;white-space:initial;width:initial;word-break:initial;word-spacing:initial;z-index:2147483647;"></div> <div style="color:initial;font:initial;text-rendering:initial;writing-mode:initial;zoom:initial;alignment-baseline:initial;backface-visibility:initial;background:initial;baseline-shift:initial;border:initial;border-radius:initial;border-collapse:initial;box-shadow:initial;box-sizing:initial;caption-side:initial;clear:initial;clip:initial;clip-path:initial;clip-rule:initial;color-interpolation:initial;color-interpolation-filters:initial;color-rendering:initial;columns:initial;column-fill:initial;column-rule:initial;column-span:initial;counter-increment:initial;counter-reset:initial;cursor:initial;display:initial;dominant-baseline:initial;empty-cells:initial;fill:initial;fill-opacity:initial;fill-rule:initial;flex:initial;flex-flow:initial;float:initial;flood-color:initial;flood-opacity:initial;height:initial;image-rendering:initial;letter-spacing:initial;lighting-color:initial;line-break:initial;list-style:initial;margin:initial;mask:initial;max-height:initial;max-width:initial;min-height:initial;min-width:initial;opacity:initial;outline:initial;overflow:initial;padding:initial;perspective:initial;perspective-origin:initial;pointer-events:initial;position:absolute;ruby-position:initial;shape-rendering:initial;size:initial;speak:initial;stop-color:initial;stop-opacity:initial;stroke:initial;stroke-dasharray:initial;stroke-dashoffset:initial;stroke-linecap:initial;stroke-linejoin:initial;stroke-miterlimit:initial;stroke-opacity:initial;stroke-width:initial;table-layout:initial;text-align:initial;text-align-last:initial;text-anchor:initial;text-decoration:initial;text-emphasis-position:initial;text-indent:initial;text-overflow:initial;text-shadow:initial;text-transform:initial;text-underline-position:initial;transform-origin:initial;transform-style:initial;transition:initial;vertical-align:initial;visibility:initial;border-spacing:initial;white-space:initial;width:initial;word-break:initial;word-spacing:initial;z-index:2147483647;"></div> <div style="color:initial;font:initial;text-rendering:initial;writing-mode:initial;zoom:initial;alignment-baseline:initial;backface-visibility:initial;background:initial;baseline-shift:initial;border:initial;border-radius:initial;border-collapse:initial;box-shadow:initial;box-sizing:initial;caption-side:initial;clear:initial;clip:initial;clip-path:initial;clip-rule:initial;color-interpolation:initial;color-interpolation-filters:initial;color-rendering:initial;columns:initial;column-fill:initial;column-rule:initial;column-span:initial;counter-increment:initial;counter-reset:initial;cursor:initial;display:initial;dominant-baseline:initial;empty-cells:initial;fill:initial;fill-opacity:initial;fill-rule:initial;flex:initial;flex-flow:initial;float:initial;flood-color:initial;flood-opacity:initial;height:initial;image-rendering:initial;letter-spacing:initial;lighting-color:initial;line-break:initial;list-style:initial;margin:initial;mask:initial;max-height:initial;max-width:initial;min-height:initial;min-width:initial;opacity:initial;outline:initial;overflow:initial;padding:initial;perspective:initial;perspective-origin:initial;pointer-events:initial;position:absolute;ruby-position:initial;shape-rendering:initial;size:initial;speak:initial;stop-color:initial;stop-opacity:initial;stroke:initial;stroke-dasharray:initial;stroke-dashoffset:initial;stroke-linecap:initial;stroke-linejoin:initial;stroke-miterlimit:initial;stroke-opacity:initial;stroke-width:initial;table-layout:initial;text-align:initial;text-align-last:initial;text-anchor:initial;text-decoration:initial;text-emphasis-position:initial;text-indent:initial;text-overflow:initial;text-shadow:initial;text-transform:initial;text-underline-position:initial;transform-origin:initial;transform-style:initial;transition:initial;vertical-align:initial;visibility:initial;border-spacing:initial;white-space:initial;width:initial;word-break:initial;word-spacing:initial;z-index:2147483647;"></div> <div style=""></div> <style> @media print { .ms-editor-squiggler { display:none !important; } } .ms-editor-squiggler { display:block !important; height:0px !important; width:0px !important; } </style> <div class=ms-editor-squiggler></div>
投稿済み Fri, 28 Apr 2023 00:00:18 GMT 、投稿者 Matthias Wieland Senior Director Support EMEA
Dear Edward Clarke! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-201478-D4Y5Y for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
