投稿済み Tue, 02 Jan 2018 14:55:33 GMT 、投稿者 Denholm Kirkham Document Solutions Specialist
Hi There,
When I add a select list from a local data connector, for some bizzare reason it adds spaces onto the end of the entry. This is playing Havoc in the workflow when the customer is coding an invoice as the entry needs to be from the select list but when input in the previous step it has the spaces etc.
Is anyone else having this issue? I've tested on a few of our cloud customer with various Local Data Connector and its doing it for all of them. Currently to get round the issue, I have disbaled the Select List Only option in the Form part of the Workflow.
Regards,
Denholm
投稿済み Tue, 02 Jan 2018 15:38:58 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Denholm,
If you have tested different data from different tables and are getting the same result - that is, spaces being added - then it sounds like a bug.
Please open a service request so we can investigate and report it.
投稿済み Wed, 03 Jan 2018 10:08:55 GMT 、投稿者 Denholm Kirkham Document Solutions Specialist
Hi Phil,
Thank youi for getting back to me. I can confirm I have logged a support call for the guys to take a look.#
Kind Regards,
Denholm
