投稿済み Thu, 28 Jun 2018 19:57:12 GMT 、投稿者 Jovan Lewis
How can you help me with my Docuware issues?  What am I not doing?
!. When QB invoice is printed is status should read Booked and link to POS Invoice, which matches the POS Num and change status to Booked.  The sample below shows that it is linked.  The POS Invoice status did not change to Booked.  How do I get them to link (change status)
2.  Moving from 1 list to another.  When document is moved to Overdue the status still remains as New.
There’s a New, Overdue and Complete.  When document is printed it status is New.  If the task ticket is not complete with 3 days it should move over to the Overdue list and change the status to overdue.  Finally the scanned document when completed should change the status to complete, when documents are linked.  I’m not sure what process I’m I using.  The document should be matched by the POS Num field. See below
投稿済み Fri, 29 Jun 2018 09:53:00 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Jovan,
Your screen captures are not visible. Perhaps you could re-upload them. Please also describe what DocuWare technologies you are using to process these documents. For example, Workflow Manager? Task lists and stamps?
投稿済み Fri, 29 Jun 2018 11:37:21 GMT 、投稿者 Jovan Lewis
I'm using DocuWare 6.11. I'm using Task list.
https://www.docuware.com/sites/default/files/forums-images/Capture_12.PNG
https://www.docuware.com/sites/default/files/forums-images/figure%202.PNG
