投稿済み Sat, 28 Oct 2023 18:31:23 GMT 、投稿者 Panagiotis Basakidis Software Solution Specialist
Dear all,
I have setup a Docuware cloud system for testing purposes for our company. I have created a text file that contains "Document Type" and "SubType" fileds that I need to import to the system and connect to each other so when selecting a specific Document Type only some of the SubType fields will be available for the user. In order to do so I have to be able to configure single and multi column select lists that are configured through database connections. Now my issue is that although my user has full access rights in Docuware, when I open Docuware Administration I am not allowed to add any new storage locations and I can not configure the already existing one. The purpose is to import a .txt file in order to use two columns that will be matched with 2 Docuware index fields. Could someone help with this issue. Thank you.
投稿済み Mon, 30 Oct 2023 09:05:59 GMT 、投稿者 Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Panagiotis Basakidis,
the storage location configuration can only be used on on-premise systems. If you need to create file connections in a cloud system, the file needs to be uploaded to the DocuWare Cloud FTP Server. (Go to web configuration -> FTP)
You can find more details in this KB article: KBA-35850
