投稿済み Thu, 08 Dec 2022 17:05:01 GMT 、投稿者 Daryl Foxhoven
I have a customer that needs to be able to "edit" Word docs they are storing in DocuWare.  However, once the final revision is made (we have a Workflow changing the Status=Final) they want that document locked down so it's View ONLY.  Is there a way to accomplish this WITHOUT having to create a separate file cabinet...if so, how?
Thanks!
投稿済み Fri, 09 Dec 2022 08:59:11 GMT 、投稿者 Simon H. Hellmann Toshiba TGIS GmbH |
Hi Daryl,
this sounds like a use case for index value profiles in the file cabinet. With those, you can set up edit rights for all documents where "STATUS does not equal Final" for example.
