投稿済み Fri, 29 Jul 2022 23:31:53 GMT 、投稿者 Hameed Ogbara Technical Support
Two documents are stored in the file cabinet and I want to search for the two documents at the same time using an index field. E.g. Index field created is doc. no. and we have two doc no. 013 and 014. can I search for the two numbers at the same time using the doc. no.
投稿済み Mon, 01 Aug 2022 20:25:54 GMT 、投稿者 Kevin Fultz Engineer Software Support
This may help.
Using Search Parameters for Targeted Results (docuware.com)
投稿済み Mon, 01 Aug 2022 21:17:09 GMT 、投稿者 Hameed Ogbara Technical Support
Thank you Kevin. This was helpful.<br> &nbsp;
