Veröffentlicht Fri, 29 Jul 2022 23:31:53 GMT von Hameed Ogbara Technical Support
Two documents are stored in the file cabinet and I want to search for the two documents at the same time using an index field. E.g. Index field created is doc. no. and we have two doc no. 013 and 014. can I search for the two numbers at the same time using the doc. no.
Veröffentlicht Mon, 01 Aug 2022 20:25:54 GMT von Kevin Fultz Engineer Software Support
This may help.
Using Search Parameters for Targeted Results (docuware.com)
Veröffentlicht Mon, 01 Aug 2022 21:17:09 GMT von Hameed Ogbara Technical Support
Thank you Kevin. This was helpful.<br> &nbsp;
