投稿済み Tue, 02 Dec 2025 07:14:11 GMT 、投稿者 Gintautas Rokas IT Engineer
The customer has an accounting program and this program only supports data import in XML format. The customer wants to import purchase invoices into this program.
I want to use docuware tools for this. Do I understand the implementation correctly?
1. With Docuware export invoice to csv format;
2. then I need an additional converter csv -> xml;
3. import document into accounting system.
Or is there a faster way to do this? In this case accounting system does not support API
投稿済み Wed, 10 Dec 2025 00:00:18 GMT 、投稿者 Matthias Wieland Senior Director Support EMEA
Dear Gintautas Rokas! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-278013-W0W0H for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
投稿済み Mon, 15 Dec 2025 07:00:00 GMT 、投稿者 Beytullah Gezginci
In addition to the option you mentioned,
DocXporter, you can export an XML file with the index entries.
For more Inforamtion: https://knowledgecenter.docuware.com/docs/docxporter
