If you do not have the value must be from select list set at storage then you can enter any rubbish you want. Without testing the specific behavior of whether the field is empty or contains an invalid entry I'm not sure what happens during editing, but I suspect that if the field is empty it will be ignored, because of the must not be empty (required) flag is not set. The bogus entry may be trapped. Phil Robson Senior Director Support Americas
As I said, the only problem is that there is no error message issued to the user. Otherwise it if failing to update as it should. The issue is fixed in DocuWare 7.
ヘルプを入手
