投稿済み Mon, 09 Jun 2025 12:45:48 GMT 、投稿者 Gintautas Rokas IT Engineer
Maybe someone can find a way to run DocuWare.Export in the background?
C:\Program Files (x86)\DocuWare\Export\DocuWare.Export.exe
the problem is that task scheduler run only app, but I need to press additionally "Perform Export Now" button.
Has DocuWare.export.exe CLI (command-line interface)?
command like
C:\Program Files (x86)\DocuWare\Export>DocuWare.export.exe /?
or
C:\Program Files (x86)\DocuWare\Export>DocuWare.export.exe --help
gives nothing
I need to run exe file with my configuration (attached) every hour in background
投稿済み Tue, 17 Jun 2025 00:00:37 GMT 、投稿者 Matthias Wieland Senior Director Support EMEA
Dear Gintautas Rokas! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-264721-R2Z8G for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
投稿済み Wed, 18 Jun 2025 06:00:00 GMT 、投稿者 Manuel Brausch Technician Software Support
When the export is configured to run on a schedule, the process takes place automatically in the background without opening the application or the need for manual user interaction.
Further information can be found in this article: https://support.docuware.com/en-us/knowledgebase/article/KBA-36581
投稿済み Tue, 10 Feb 2026 08:29:27 GMT 、投稿者 Mathieu Sénécal LCS Group Senior Consultant
If I understood your needs, you should be able to make DcW Export run and generate files automaticaly, without any human action, using the Windows Task Scheduler.
To do so, you just need to run the DcW Export as an administrator to be able to access and configure the task by clicking on "Click here to run this export on a schedule". In the Windows task scheduler, you can finetune the needs (frequency, etc...).
Then, you just let it run on its own.
KR,
Mathieu SENECAL
