投稿済み Fri, 10 Sep 2021 13:17:07 GMT 、投稿者 Doug Murphy Sales Solutions Analyst
I am trying to create a workflow that will notify a user when a document is about to expire. I have an index field named Term with values in a restricted drop down list (30, 60, 90 and 120 days). I have a date field that will be my starting point. When the current date = expire date + the term number is when i want the notification to trigger.
Example - Expire date = November 5 2021
                  Term = 60
                  Result should be September 5 2021 to send the notification
Any help would be appreciated
投稿済み Fri, 10 Sep 2021 14:42:06 GMT 、投稿者 Simon H. Hellmann Toshiba TGIS GmbH |
Hi Doug,
first, you need to calculate the date for the notification.
For this, you can use an arithmetic expression with DateAdd() and store the result in a DateTime variable.
Next, you can create a time delay step which delays until the date from your variable is reached.
Keep in mind that time delay needs a date with time. When writing a date without time to a date variable, the time is automatically set to 12 pm UTC.
You might need to use a second DateAdd() to set the time to a different value.
Once the DateTime is reached, your task is triggered.
