Veröffentlicht Tue, 05 Jan 2016 20:29:44 GMT von James Auman North Carolina Rate Bureau IT Systems Engineer
I have a moved our Fortis environment to a new server using the move procedure documented on this website.  When i launch View Station, i sometimes get this error (see attached). I cannot figure out what makes the error occur.  Sometimes it works, sometimes it doesn't.  Any ideas?
NOTE: I notice similar errors on the other Fortis client products like system admin or database admin.  Different lck file but same message
https://www.docuware.com/sites/default/files/forums-images/fortis%20error%20lock.png
Veröffentlicht Tue, 05 Jan 2016 21:05:05 GMT von Patrick Seresin Product Quality Support Analyst
Jim,
See the following article:
https://www.docuware.com/support_faq/?solution_id=3879
Veröffentlicht Wed, 06 Jan 2016 13:30:57 GMT von James Auman North Carolina Rate Bureau IT Systems Engineer
I checked and i have full control to all the folders, subfolders and files.  I did notice that i'm not seeing the error on the first desktop installation.  Have you seen an issue with running View Station and other Fortis client apps on Windows Server 2012R2?  Something about the server OS that is different that causes issues with View Station?
Veröffentlicht Wed, 06 Jan 2016 13:41:54 GMT von Patrick Seresin Product Quality Support Analyst
Jim,
Please contact your partner Ricoh (800-706-4566 or softwaresupport@ricoh-usa.com) for further assistance.
Thank you,
Veröffentlicht Tue, 22 Mar 2016 09:32:13 GMT von Darren Gray
You can run an iso file inside windows providing you have winrar winzip etc. Right click the iso file and use extract . This will give you the optiopn of unpacking the iso file into a folder of your choice. Once unpacked you can access all the files with the folder you placed it into
Clay Anderson / Academic writer @ online college essay writing service
